Hello.
I just found my Left H-K SUB-Woofer broken. Not the membrane but the bended yellow part between the cone tube and the driver. (I don't know the word for it)
By the way.. someone told me I can't swap them (both side) with an alternative SUB drivers.
I was thinking to place the JL Audio but someone told me the H-K is a 2-Ohm SUB 200mm (7.87 inch) drivers.
Can anyone have the right dimension and specifications so I can find a better solution instead to buy the HK again?
Thank You
Regards
Thank You
Regards
