1 - 8 of 8 Posts
'97 SL 500, 80K miles
I am trying to remove the Hardtop for the dry season in Vancouver and when I tried to operate it there are no sounds and no actions when I pull back on the red button but it does Flash. When I push forward after trying that I can hear the rear cylinders operating and the button does not flash. I have checked the fluid level in the reservoir and it is up to the mark. I am leary of using the hand tool to unlock the fronts (and backs) as I will need to be able to operate the soft top and until I am sure it will work I don't want to rely upon it.
Any suggestions ?
1999 SL500 Sport, Black Opal Pearl, Helios Leather, Pano roof, AMG Aero2 18"Split Rims, Rear Seats
When you pull the switch do the Windows go down? Check the fuse in the boot/trunk, maybe a bad connection
The windows do not operate but the fuses all appear to be good. When I first tried to remove the top I started with the windows down so did not notice the failure to cycle.
1987 560SL Gone but not forgotten! & 1999 SL500 For Now
Can you raise & lower the widows with the WINDOW control buttons on the console?
Bob
Should have read the forum better
Following the comments about the Windows - I tried to reset the windows as part of the process on the assumption that they were not re-set when the mechanic worked on it recently. It worked and now the top works and I have a convertible again.
Life is good (again)
Well done, congrats! Now enjoy your ride-
Bob
Sl500 1997
All problems at Hardtop is from position sensors
They get dirty and doesnt operate correctly
One is some time we must clear and spray them
I had that problem and Star Diagnosis didnt read the problem.
I reprogramed roll bar,Cleaned door keys and htop sensors and now
It works like a dream :D
1 - 8 of 8 Posts
