hows it goin everybody, new to the site and im excited to see how much help everyone is on here, so heres my problem
i just purchased a 1998 slk 230, the top went down just fine, drove for a few hours, then when i got home and tried to put the top up, the roof came up and latched but the trunk wouldnt close.. it just stayed in the up position... so i pushed the switch to open and it retracted inside the trunk all the way no problem... when i got home and tried it again the same thing happened... top goes up but the trunk will not close... and now it wont do anything... the motor does not run, no pump actuation noise or anything
so now here i am, convertible top is up and latched, the trunk is up backwards, all the windows are down, and nothing is working at all... i can start the car with the parking brake on, and try the interior switch (which is lit up red, but not flashing) and it doesnt do anything...i took the plastic liner out from the inside of the trunk and there arent any leaks, the fuses in the trunk are fine (and i have the microswitch for the "roll cover" taped close as well so the computer reads that its in its proper position)since i had to disconnect from the plastic cover to get it out
besides this, is there a way i can manually close the trunk and get the top secured so i can move the car, i dont want to hurt anything on the car and have heard about manually close procedure but i dont have an owners manual to the car, any and all help will be greatly appreciated..:bowdown:
