83 230te euro
lately my 230te cranks several times above normal before starting. Electrcals are ok batt., alt.,starter., could it be fuel supply prob.???? HELP[:(] Thank you all
1983 300Dturbodiesel
on mine if i crank it right after the glow plug light goes out, it tunrs a few more times ...
on mine if i crank it right after the glow plug light goes out, it tunrs a few more times than if i wait 2 seconds more...
84 230CE & 84 300DT
It looks like you have a gasoline model by the your vehicle listing. Check your distributo...
It looks like you have a gasoline model by the your vehicle listing. Check your distributor cap and rotor for corrosion and then your spark plugs. Even though you may have electronic ignition, you still have to replace the cap and rotor occasionally.
