1991 Mercedes 300E 3.0
Just bought a 1991 300E 3.0 Gave it a tune up, Plugs, wires, air filter, Cap and rotor. very hard to start in the A.M. after sitting all night. After warmed up (1-2 min) it runs fine. Also has a rough Idle. Any feedback would be appreciated.
1990 300E 2.6L 144K
Replace the OVP relay. It is located behind a plastic housing behind the battery. I experienced similar problems and replacing that helped my car significantly.
While you are at it, I suggest that you complete your profile so that other members will be able to help you more effectively.
Andrew
Your Parts Search Returned 1 Part(s)
2005 E55
Before the OVP.
Premium ethanol free gas. ( shell 91)
Copper plugs
Fuel filter
Air Filter ( if dirty)
hard start
Thanks for the info. I pulled the fuse on the OVP and was fine. The ABS light came on so. Can the OVP still be bad?
1991 300D 116,000m
The OVP fails from the cold solder joints within. I'm not convinced this is your problem, however it's always good to keep a new spare in the trunk.
Since it's only cold starts, I would lean towards the fuel pressure accumulator. I did a simple search and found this. Post 6 is helpful. CBC_ATL always comes through with the links, lol It appears that this fixed the poster's problem. Good Luck.
http://www.benzworld.org/forums/w124-e-ce-d-td-class/1654017-1991-300e-cold-start-issue.html
