Funny thing happened the other day. drove the car 60 miles then shut it ff for about 2 days. started it up and drove back the same 60 miles,...no problems what so ever. i get into town and go to apply the brakes before a stop sign and i get a real hard pedal and it takes forever to stop the car. i proceed to park the car on the street and put it in gear. i turn the key to shut it of and nothing. it keeps running. it has been 2 years since i had vacuum issues. i lift the hood and hit the STOP button. i start the car up and drive it slowly around the neighborhood and keep applying the brakes...still does it. then on like the 5th try, the brakes kick in. that was 3 weeks ago and the problem never resurfaced. Now i have 4 new pads, rotors and calipers, new brake line, new vacuum hoses and connectors. checked the fluid and thats fine.
only thing that i have noticed is that when the temp on the climate control is set to minimum, it still seems hot for a long while. (i also have a rebuilt control panel, receiver drier and temp sensor). the ac was switched to r1341 with all the new fittings. the only thing left is a new compressor as mine i gues leaks (420.00). when i switch the ac, i do not hear the compressor kick in. the mechanic may have diisabled it until i had it done is my guess. so that i would not have done damage. so what do you think? anything tied together? seems odd. this car is like "christine" in the fact its alive. when i contemplate a newer one, she acts like a brand new car..not wanting to piss me off. its weird.
1985 Euro 300TD Turbo, 1983 Euro 300TD turbo, 1979 Euro 240TD and 1981 300D converted to euro.
How old is the vacuum pump? And your brake booster might be bad....mine did the same thing and it was the brake booster..... i used the one off my old 77 and its been fine sence. If the vacuum pump is going then just get one at a junk yard coz 9 times out of 10 they have already been replaced.
