1 - 20 of 42 Posts
1994 s600 coupe
posting this question here in this forum, because perhaps it will get more hits and replies here, being it's a W140 car, new to forum this is my 2nd post:
recently rescued an ailing 1994 S600 coupe with V12. complete car except for owners manual, right side distributor cover, and battery. no fuel pressure, but it would start and run on ether starting fluid. towed to friends garage. changed both fuel pumps, filter, battery, hit key varoom it started right up. front brake calipers were locked from sitting. changed those along with brake hoses and pads, fixed that too.
it will need rear brake lines, and the hydraulic lines in front left inner fenderwell.
I'm 57, been working on cars and as mechanic for 40 years now. built a ton of engines from bare block up, all American V8's, and a few V6's. body off restos, transmissions, rear axles, paint jobs, total suspension rebuilds, alignments, exhaust, interior, glass, you name it. built cars from bare frame up since I was in my 20's.
but I never owned a Mercedes, or worked on them much. there was an old '73 V8 OHC 4 door at the lot I worked at, in 1984. it always intrigued me, should have bought it. it was only $1500 back then, and ran like a top, but was getting rusty...
anyway, I'd like to get a handheld scanner for this '94. I have no intentions to reprogram any modules online, or use a laptop. IMHO, when it gets to the point you're connecting a laptop to your car, it's no longer a car. it's become an aircraft or space shuttle and too complex. want to keep it as simple as possible. I just want to see datastream info, isolate the bad sensor or part or wiring, and replace it, if need be.
as of now I don't even know if the sensors are working properly or communicating with the ECM's. I have an OBDII scanner, I can adapt it to the underhood 38 pin plug, but have been told my scanner will not recognize the language. haven't tried it yet, the adapter is on its way.
I do have access to the latest $15,000 Snap-On box black box scanner, but the shop does not have the Mercedes 38 pin cable adapter. we will try my adapter when it arrives (I've ordered it).. but I still want my own handheld scanner to use at home on the car, and keep in the trunk.
what vintage or new handheld scan tool, will display/erase codes, and give datastream information on the engine/transmission primarily ? if it did other modules too, great, but not a necessity. I'd disable any superfluous systems before I'd spent a lot of time diagnosing or repairing them. I just want to get it running good, and step on the V12, and have some fun. when you're banging on 60, time becomes a factor, cuz at that age, you're running out of time. any help from you guys would be great and really appreciated.
thanks much, looking forward to any and all replies, no matter how rudely awakening they may be....I'm expecting a "no" answer.
1999 Vito 113 638.114
Sadly, your '38 pin adapter' cable that seems such a bargain will not convert the old analog electrical voltages to interface with modern digital OBDII scanners.
There is a reason they don't supply that 38 pin cable with the scanner.
While the plugs will physically fit, the electrical and data protocols your vehicle and the scanner speaks both are entirely and wildly different.
Even if your Snap-On scanner would support the protocols, you will probably find that the current version of software would only go back to the late 1990s anyway.
How do I know? Asked and wondered aloud at the local mechanics. Got a fleabay OBDII plug and a 38 pin adapter cable, and they didn't work with the scanner the mechanic had.
Experience and hindsight is a wonderful teacher!
1991 S600 Japanese market
With my 1992, Ive had great luck with my LED blinker tool. Ive also found it extremely usefull to pull computers and measure voltages, resistance and waveforms directly from the pins the computers plug into.
1994 S600 Coupe, 1995 S600 Coupe
Back in the day, there were a few handheld tools, chief among them the Mercedes Handheld Tester (HHT). It was discontinued by Mercedes, and emulation software written for Windows, called HHTWin, replaced it. It is the portion of the software that is still used to diagnose W140s by Mercedes. It requires a laptop and a multiplexer unit. I've not seen an actual HHT for sale. There is one YouTube video I've seen of one in use. HHTWin is pretty much an exact duplicate of the old HHT.
There were also a couple of aftermarket handheld units sold that did W140s, but they are long out of production and very scarce. They were marketed by Tresco and Baum tools. I have one of the ones made by Tresco, and I looked for a couple of years before I found it. I bought it as I thought it might be more convenient to take on trips. It's adequate, but HHTWin is far better. Support for the old scanners is non-existent, and there is at least one late model function it doesn't cover. The one I have is handheld in name only, and is pretty big and bulky. A small laptop and multiplexer is easier to use, covers all functions, and really isn't much bigger. I take it with me in a small computer bag.
I don't know of any aftermarket scanner that covers all W140 functions, particularly early cars. Late W140s have OBDII, but only for the engine and emissions items. You can use a blink code reader, but that won't give you live readouts like HHTWin.
One last word, stay away from Carsoft. Multiple reports say it doesn't work at all.
'95 S600
I've access to over dozen hand held scanners at my old work and if they had the 38 pin connection with a Mercedes multiplexer box then they stood a good change of working, if you are trying to use a standard OBD>38pin then its not going to work.
We had a Hanatech P1 and a older Autel Maxisys and both worked on my W140 using the supplied multiplexer. One of the newer scanners i cant remember had the multiplexer but didn't support W140 as they must of phased support out.
Nothing beats the Chinese STAR clone on a laptop for the price (plug and play with the correct laptop). You are also guaranteed compatibility and access to everything. Scan tools do tend to miss a lot of useful factory features.
1994 S500 Coupe
With my 1994 V8 Coupe, I totally get what you mean about attaching laptops to cars and them becoming more than just something with four wheels.
But unfortunately with the W140 it's like an F-14 from the 1980s. Filled with computers that speak in an analog way, unlike today's cars that are pretty much digital speaking computers.
The W140 has a complex arrangement of computers in what's called a CAN bus. They all speak to each other like they're on a network. Even more so with the V12s with master/slave throttle bodies and twin fuel injection computers for each bank.
I can echo what has already been said. I myself use the laptop with multiplex arrangement, simply for HHTWIN, which is an emulation of the handheld scanner Mercedes used. The pre-1995 models, like you and myself have were before ODB2 became the standard hence why nearly all ODB2 compatible scanners will be unable to read anything. If one does, I'd be surprised.
1994 s600 coupe
I fully expected this, but got the connector anyway, there are old red box model 2500 snap on scanners for sale relatively cheap used, 1990's vintage. going to give it a shot for the non-engine ECM's see what it may pull up. thanks for verifying with first hand experience. a tech on another site stated it may work on non-engine ECMs. it seems to me a company like snap-on woulda have something for the car back then, they were and are widely considered the go-to scanner company for shops in my area of the country. every independent shop has a black box Snap On scanner now. that one will almost definitely NOT work. asked them where's your old red box ? answer: they trade them in and get money back when they upgrade, nobody keeps them.
1994 s600 coupe
when Computer Command Control first came out in early 1980's, with solenoid operated carburetor metering and fuel injection on American cars, we used to jumper 2 terminals on the underdash ALDL, and the check engine light would blink the codes, counting the blinks. those systems still exist on what few older cars are still running out there. they came out with a 3 prong plug that just plugged in and jumpered it and blinked the codes, but I always used a bent paper clip. when the early OBD1 scanners came out around 1990, hey we thought we were real big time cuz we got a little box with a cord and buttons to plug in....:D
it's funny now to see those little 3 wire boxes to blink codes, for sale on Ebay, for Mercedes. it's like back to the future or something. wanna make some money ? design and build an OBD1 scan tool for 1989-95 cars, that actually works and does everything. no online support needed, axe the reprogramming thing. it would sell, there's a lot of these cars out there yet.
1994 s600 coupe
HHTWin is far better. A small laptop and multiplexer is easier to use, covers all functions, and really isn't much bigger. I take it with me in a small computer bag.
now we're getting to the meat of the subject....QUESTION: what HHTWin system do you use, is it a bona fide Mercedes Benz vintage laptop system you obtained ? if so, how can I get one ?
could you post some pictures of the kit ?
seems to me a guy with that setup could make some money today, just about every car out there has some little gremlins that need to be fixed in that system. it's so complex vegas odds say, none of them run 100% unless they're low mile, garage kept examples. let's face it, what the dealer wants to fix these old cars, you could buy another car, or at least half a really nice car. there are cherry examples out there for only $10,000 now.
1994 s600 coupe
I almost bought one of those yesterday, but started this thread instead, wanna make an educated decision. thanks advice taken. they are somewhat affordable, I think without the HDD and laptop they are down to around $200-$300 new ? and around $500 for a complete one ? hesitated cuz I read reviews online and quite a few guys had problems with them, depending on vendor.
1994 s600 coupe
Discussion Starter #11
exactly...the ECM's and engine management are borderline insanely complex for a car. It reminds me of a Spitfire or P-51 engine on computer steroids. my brother took one look at it and said, it's like an airplane engine. repeat question, where do you get the HHTWIN software, laptop, multiplex, could you post pics of your kit, and description ? any laptop will work ? cables needed ? thanks.
Several of us here have bought this system:
http://s.aliexpress.com/j2QrABrU
Works well. They may sell it complete with a computer also. If not, get a D630 Dell off eBay for $75 or so, and plug the hard drive they send you into it. Specify that you want the hard disk for a D630, not USB. Upgrade the D630 to 3gb ram if it isn't already. Ask the STAR seller to use an SSD for the hard disk. It will cost a little more but well worth it. Makes everything MUCH faster.
The kit comes with the multiplexer, cables, and the harddisk with the software. There is a software password setup process you have to do once you get it, as the software is locked to the computer hardware. They can connect to the computer over the internet and do it for you.
As a bonus, you get EPC and WIS on the harddisk also. Those are the parts and workshop manuals.
1994 s600 coupe
Discussion Starter #13
JAL, thanks much. just a few questions...
am I understanding this right,
the multiplexer just acts as an interface,
between the laptop and car.
or, does the laptop connect directly to the car ?
does a multiplexer have any diagnostic capabilities, on its own ?
cuz it sorta looks like one of those big brick scanners,
yet it's not called a scanner per se, it's called a multiplexer.
I've dealt with multiplexers in audio/stereo before,
basically they took one channel or 2 channel, and split it to many more.
please explain if you would ?
one more thing, I see online there are both C3 and C4 versions, what's the difference besides price ?
if they both would do the job, what advantage is the C3 ??
C3 is older design. This one is sort of between a C3 and C4. But we've had consistent good luck with them. Unfortunately, any of the clones are a crapshoot anymore due to obsolete components, but these seem to work well.
The laptop attaches to the multiplexer with a serial cable, and the multiplexer attaches to the 38 pin port. The multiplexer gets power from the car. The serial port is required, which is why we use a D630. D630s are also common and cheap. You can't do anything with the multiplexer without a laptop. The multiplexer takes configuration info from the laptop and configures itself to read the proper info from the car. Basically it takes signals from the car and translates them into what the computer can read, and vice versa. Kinda linked how a audio multiplexer takes a Dolby digital signal and converts it into 5.1 or 7.1 outputs.
Mercedes Star is the overall name for their diagnostic system. It contains HHTWin, DAS (a later system), and Xentry (an even later system). There is no way to get just an HHTWin system, although it would be technically possible. You get all three.
There are a couple of threads on the system on the R129 forum.
1994 s600 coupe
Discussion Starter #15
thanks JAL, I get it now...
that's what my intuition was telling me,
otherwise why have a laptop and multiplexer
need both.
having said that, what does the dealer use now ?
laptop/multiplexer, or modern handheld ?
gut tells me they got so complex a handheld can't do it all.
need both.
They use a laptop with a simplified interface called VCI. In between the VCI and C4, they had SD Connect, which was super complicated and not really reliable. SD Connect was basically a whole Windows computer in the interface, but you still needed a laptop to control it. Supposedly, the VCI can do HHTWin, but I'm not sure. I hope the VCI gets cloned, and works with HHTWin, because it's new technology.
'95 S600
NZ, is that Chinese clone a C3, or C4, or ??
https://www.aliexpress.com/item/2014-Cost-Effective-Mb-Star-C4-for-both-Cars-and-Trucks-with-Xentry-2014-01-Version/1783909054.html?spm=a2g0s.9042311.0.0.61784c4dNsphQN
That the ones that has been linked many times on these forums when i bought it and i dont believe anyone has had any issues with it. I did get it on special along time ago when it was $299, maybe suitable better vendors as linked.
I agree about the SSD as their supplied HDD was 5400rpm which is very slow when load the software package, i rarely use the software so its not a major.
1994 s600 coupe
Discussion Starter #18
I'm posting this for reference only, cuz it sounds unbelievable. I called Snap-On corporate tech center today, asked them if their latest scanner would get live datastream information, and pull codes from 1994 S600 w/V12 engine. he looked up specs said it would, with the common adapter plug from OBD2 to round 38 pin Mercedes. the only way this could happen is with some sort of multiplexer inside the Snap-On scanner. the adapter plug is only $7 and already on its way, so we'll just see about that. new Snap-On scanners are not cheap, they are anywhere from $6,000 to $15,000 depending on the package. 2 local garages have them and both agreed to give it a try. I want my own setup anyway but this will be a good experiment. I'm expecting it not to work. How could it ?
It may pull some codes, but how many? Of course, for that much money, it ought to pull them all. Not very cost effective if you want your own solution though.
I thought snap on charged extra for various car types. They used to have keys of sorts that were basically dongles to give access to optional models and years. Don't know if modern snap on systems are like that or not.
W140 Moderator
"CHRIS" Merc 92 600SEL / Sold > 93 600SE / 93 S500 / 89 560SEL / 413CDI / B180-CDI /A170-CDI
94V12, To help you out a little more clearer , i made a short video for you . This is my MB Star C3 Scanner , best Gadget i ever bought for the car (in a way) .
This is a must have for your Space Shuttle there not the other scanners .
C3 or C4 Scanner , C4 has the only advantage of having wireless network to the scanner the rest is the same .
What you see in the video is just a small sample ,there is much much more you can do & scan or tune or reset . I for example have done a reset on booth Camshaft sensors & other values ,engine sounds like a Swiss watch atm .
I ad a link where i bought mine ,the seller Ary is extremely helpful with everything .
The Black box is a box from a Drill which i modified , i bought two Mercedes Perfume bottles that had the Silver MB Star logo on it which i removed from the bottles then stuck them onto the box , looks cool , i don't use perfume soooo ,lol.:thumbsup:
Postage was Traceable all the way ,arrived almost instantly ,5 days posting time . If he has none on auction sent him a message if you interested.
https://www.ebay.com.au/itm/MB-Star-C3-Pro-Diagnostic-Tool-NEC-Relays-Multiplexer-Main-Unit-HDD-Software/323756933979?ssPageName=STRK:MEBIDX:IT&var=512748361500&_trksid=p2057872.m2749.l2649
1 - 20 of 42 Posts
