1986 Sel
Hi Guys, Just had my brake disk and rotors replaced and now the handbrake wont always release unless. Taken it back and they cant seem to find a fault. Sometimes after I drive of it will then release and other times not. Seems to be more apparent when the handbrake had been applied for sometime.. Any ideas how I can fix this? Was fine before I had the brakes done.. Many thanks if anyone has some advice....
Slightly creased
2015 ML 400 x 2
the handbrake is a mechanical brake shoe on each rear wheel, either they are sticking, or the cable is sticking. A decent brake place should be able to work it out and fix it...
1979 280SL, 1984 280SL
The parking brake mechanism inside the rear drums tends to rust from disuse, and is a common problem. Get in there and clean it all up you should be all set.
