Some time back I had a garage change the hand brake cables on my 53 plate 112. In a relatively short space of time the handle was coming most of the way back. As I am losing faith in garages, I decided to see what was up with it; I did wonder if the new cable had stretched and just needed a bit of adjustment. I couldn't see any cable adjusters so decided to take one of the back wheels off. I removed the disc caliper and then the hand brake drum. The brake shoes seem to be on the piss and seemed to be operating on the chamfered section of the drum which has chamfered off the linings. The spiny adjuster wheel was pushed against the spring that holds the the shoes together which didn't look right. The ends of the shoes that located in either end of the adjuster mechanism were bent. I dressed them flat with a hammer and replaced them. The back plate was pretty rusted and every part seemed very sloppy. I don't know how it should be and I'm wondering if all the parts are there. The top spring doesn't look right and I did wonder if there should be some sort of automatic adjustment.
Can anyone help with a parts diagram or similar so I have some idea of what I should be doing.
Many thanks
Rlaph
Many thanks
Rlaph
