1 - 8 of 8 Posts
00 g500
So i finally had my "sealed for life" transmission fluid changed. I had them put the magnet in the pan while they're at it. He said the fluid looked pretty good inside... about what you'd expect from a well made vehicle with 63k miles... but not new. Good to hear because i've been a little nervous about the long term service life of the tranny now dealing with more power than traditionally on such a heavy vehicle... guess it means i can really start stomping on it.
They did the double drain and fill to better purge the torque converter.
I was planning to change at 50k miles... to me it translates that 60k is o.k... a reasonable time to change it.... but that it really makes sense to change it for the long run. Fuild, filters, and a gaskets are cheap. And I trust someone to change the fluid correctly without screwing something else up in the process more than i trust someone to replace my tranny.
Off topic, the rear pads i got were supposed to be sensorless... but they had the sensor relief and the shop put a sensor back in there before i could tell them not to... I hate that stupid sensor... (but if it wasn't "no-brakes" erik driving i'd probably recommend it... espcially for someone who only does the 10k mile services.)
2000 G500 NMLE
ewalberg - 4/19/2005 6:23 PM
If anyone is interested, I've updated my writeup for this service to reflect the fact that there is a brand new MB ATF that is supposed to be better than what is in the tranny from the factory.
If you want a copy, drop me an email.
00 g500
Brake fluid... It was planned, i'll double check when i pick it up... like right now...
New Tranny fluid... is it replacing the old as standard, or is it only on special request?
2000 G500 NMLE
ewalberg - 4/19/2005 7:50 PM
I don't know much about it, except that it was designed for use in the new 7-speed auto. It is supposedly quite superior. Probably quite more expensive, too; but I don't know that for sure.
2004 MB G500 Black
I would not worry too much about the 5-speed auto holding up to the V8 power and weight. Remember, this same tranny is used on AMG models with over 450 HP and over 500 ft-lbs of torque. In fact, this same tranny is used on the V12 Bi-turbo with over 600 Hp and 700 ft-lbs of torque. From what i read, AMG only quicken the shift speed...not really strengthening it.
The 600HP/700torque limit is probably where our tranny maxes because AMG had to limit the engine output due to the tranny's limit. The new 7-speed auto is supposed to be able to handle even more output!
2000 G500 NMLE
aggragated - 4/19/2005 10:51 PM
Dutch,
How well would this fluid work in a manual 460?
It is not necessary. Why pay +$15/liter for something you don't need? Use a good brand name Dexron ATF and you'll be fine.
1 - 8 of 8 Posts
