2000 S430, 2000 S500, 2003 S600 TT, 2005 E320 CDI, 2006 S500 4Matic, and 2006 S350
Yes, I have H7 LED's in my 2006 S350, no problems. My neighbor, the original owner of the car, put 'em in a few years ago to replace the burned-out halogens. They originally were in the low-beam position; after I did a bi-xenon upgrade to the car, I put 'em in the high-beam position. They work very well. Remind me to get you the info on these.
However, I should caution you. You won't get any brighter output of light vs. a halogen bulb. No, you won't; I've done the side-by-side comparison. If you're looking for brighter light output, then you're looking at a projector upgrade, which means opening up the headlamp assembly and replacing the projectors with either bi-xenons (as I did) or the new bi-LED projectors. You must do THE ENTIRE PROJECTOR, not just the bulb, in order to do this properly and not be dangerous to oncoming traffic at night.
On the other hand, if you're just looking for a more bluish output to look cooler (nothing wrong with that, BTW) without an increased light output, then the H7 LED "bulbs" will do that very nicely, without being dangerous to others at night.
