G
Guest
·Re: H&R springs...answer:
Spring pads/buffers. This is the small rubber ring that sits atop your spring. They are different to each car. Different thicknesses=differing ride heights. If your car is too high for you, you'll need to dis-assemble it, take the spring pad off and replace it with a shorter/thinner one. They are available in 5 differing heights for 208/210. One word of caution though if you haven't driven the car much since you installed the springs, it may not have settled to its permanent ride height. Good luck, allen.<br>
