1 - 9 of 9 Posts
My Capri Blue C320 is arriving soon and I need to know which springs to purchase. I have 19' Carlsson rims and I am debating between H&R or Eibach springs. Looking for the springs that will give me the most 'comfortable' ride. Help!! Any suggestions...which one do I pick??
Discussion Starter #2
I think most ppl will tell u H&R has a more comfortable ride vs. Eibach. However, Eibach can lower yr car a bit more. They are about the same 'performance-wise'.<br> I have ordered the H&R Cup Kit 3.5 for my C32.
After reading a lot on different forums, I did Eibachs, staying with stock shocks. Ride comfort is as good, if not better, on smooth roads, a little worse on bad roads. Most said H & R were rougher, as they are more performance-oriented. I was going for cosmetics. No regrets!
It seems like everyone has differing oppinions on H&R vs. Eibachs -- with 19's. So, I'll throw in my 2 cents. I have H&R's, the ride is softer than I thought it'd be. The car tends to rebound too much on bumpy roads at high speeds (the front tires actually has rubbed on the plastic fender protector). My dealer said that Eibachs don't lower the car as much as the H&R's and the Eibachs are a little more stiffer and don't rebound as much. So, I may switch to Eibach if the front tires continue to rub on bumpy roads.<br>
Comfort = Eibach, because.....
Eibach springs are progressive while H&R are linear.<br> <br> This was what AMG Performance Group advised me.<br> <br> Beng
Re: H&R or EIBACH SPRINGS???
Which Eibach springs, the Pro-lines? Also are you using stock sport package shocks? Finally how much was the car lowered and was there any need for shims ? thnx.
1 - 9 of 9 Posts
