G
Does one brand of shox match up better with one brand of springs? What are the pros cons of each....everybody seems to say their setup is best...any objective opinions? what about a coil over system? what's the pluses of that? thanks...
G
Discussion Starter · #2 ·
H&R spring (stiff,lower)..Eibach (soft,less lower) Bilstein (popular brand) but no adjustment.......
<br> Koni, shock had external 5 way adjustment. Is also a good brand but not as popular as Bilstein but shock. As for COIL OVER SYSTEM? You get all the benefit in one system. Like ride hieght adjustable. It had two spring in one system design for street and track use. The little soft spring perch on top is design to obsorb the street bump better. But the most importance thing is that spring and shock are design to work together and TESTED for track use. Cost? $$$$$$
G
does stiffer mean a harsher ride? thus making the eibach a more "everyday driver" friendly?
