I believe your tire size is perfect for the cup kit. You can always use the spring pads al...
I believe your tire size is perfect for the cup kit. You can always use the spring pads also to tailor the fit for your car. I was going to run the exact same setup as you, but got a deal on the regular H&R springs and bilstein shocks. I will be using shorter pads though so it will be low almost like a cup kit. If you do run into trouble, just get the fenders rolled. I saw a 16v with a cup kit and tires bigger than yours (235/40R17) with only fenders rolled on one side. No rubbing problems at all.
