1 - 11 of 11 Posts
G
Discussion Starter · #2 ·
hey are you talking about shim pads?
<br> <br> i got 8mm shim pads (#1 shim pad) from the dealer, it only cost 13 dollars for two pads (i lowered the front of my black benz more than the back since it was considerably higher)<br> <br> is that what yer talking about? go to the dealer<br> <br> <p>cx544033-d.alsv1.occa.home.com
G
are you looking to lower your car?
the front of my black s class was considerably higher than the back after i put the 20' wheels on it...so i got hte #1 shim pad while the back had the stock #3 shim pad. it was an 8mm shim pad and lowered the car another cm or two. is that what yer looking for?<br> <br> -erik<p>cx544033-d.alsv1.occa.home.com
G
Discussion Starter · #5 ·
Nick..they make 5,15,20,25,30 mm but 15mm and thicker require longer wheel bolts......
<br> call www.autoclass.net and ask for GASTON. I just got my 5mm but i'm gonna return it because it not thick enough.<p>66-42-123-156.lsan.mdsg-pacwest.com
G
Discussion Starter · #7 ·
Check out http://www.wheeladapter.com/
This guy makes all his own adapters and spacers on CNC machines to your specs. His name is Fred. Tell him Adam sent you.<p>ca.216.202.172.104.gtecablemodem.com
G
Discussion Starter · #8 ·
Nick, spacers cost too much (Labor), it'll be better just get smaller rims or tires...
just a suggestion....<p>proxy4-external.alsv1.occa.home.com
G
Discussion Starter · #10 ·
i bought mine from these guys. i don't use them anymore but when i did...
they worked great. no vibrations were present. the most important issue when purchasing spacers are to make sure they are HUB CENTRIC. <p>adsl-63-203-96-93.dsl.lsan03.pacbell.net
G
Discussion Starter · #11 ·
Bruce...spacer are most of the time have nothing to do with width of the rim but the OFFSET of......
<br> the rim. You can install 16 x 7.0 rim but if the offset is wrong then you use spacer to push it out toward the fender.<p>pixie.chulavista.lib.ca.us
1 - 11 of 11 Posts
