mercedes 300sel
so i will be changing the guide rod busing on both side soon, before i do this, does anyone have advice on this? will i need a spring compressor? and while im replacing this i always like to replace any bushings or rubber pieces that appear. i heard that you can changes the subframe bushings too? anything else? and how hard will it be to remove the caster box from the firewall? anything to look for while im doing this? thanks for your help
Moderator
1991 500SEC 55K mi. 1987 560SEC Now 153K mi. 2020
Hi ladybee,
A search in the W126 section for Caster Box will yield a lot of good info on the subject.
Here's a taste from Diesel Power:
http://www.mbnz.org/forums/forums/thread-view.asp?tid=1186100&posts=10&hl=caster+box
Good Luck, MBL
