1 - 8 of 8 Posts
2016 Mercedes-benz C450 AMG 4MATIC
Hi Everyone,
I have a 2016 Mercedes Benz C450 AMG. I have cracked four of the factory rims, and decided, when I cracked the fourth, to replace the wheels with Rohana RFX15s. I ordered a set of Rohana RFX 15s with Nitto NT555 G2 tires (entire specs below). When they were mounted, the technician reported that front wheels were locking up because they don't clear the control arms. Anyone have any experience with this that can offer guidance?
Also attaching a few photos that approximate what I am trying to accomplish. These are photos of the same wheels on a W205 C63. When I sized the wheels on Fitment Industries site, the indication was that these wheels would work, so maybe there is some kind of work around?
Any help would be most appreciated.
Thanks Everyone!
Josh
(2) RFX152095112BT35 Rohana RFX15 20x9 +35mm RFX152095112BT35
(2) RFX1520105112BT45 Rohana RFX15 20x10 +45mm RFX152095112BT35
(4) 211860 Nitto NT555 G2 245/30ZR20
Wheel Tire Car Vehicle Land vehicle
Wheel Tire Vehicle Car Land vehicle
2020 Mercedes C300
Are the front wheels the same size as the OEM? Same question for the front tires. Seems like you put 245s on the front. My C300 has 225s on the front. Could that be the issue?
I would ask Fitment Industries either way.
Thanks for your reply calonzo!
You're correct, the factory tires are 225/35Rs. I needed a slightly wider tire since the Rohana rims are slightly wider than the factory ones, and I needed a lower profile tire than the factory ones to compensate for the wider rim diameter (the factory wheels were 19" and the Rohanas are 20"), hence the 30R instead of 35Rs. Admittedly this is the first time I tried to size custom wheels for a car, but I did find a formula for sizing tires online and, according to that the new wheels should fit. I had not considered this control arm issue at all. As you suggested, I have contacted Fitment Industries, and waiting for a response. If anything, it seems like it would be the wheel offset that would most affect this, if I am understanding the problem correctly. Thanks again for the reply!
- Josh
Discussion Starter · #6 ·
Sounds like you need more negative offset which can be achieved by using wheel spacers. Determiner how many mm you want / need to push the wheel out by
Thanks for the reply! I did hear back from Rohana and they said I either would need 8mm spacers or to get the wheels with a 25mm offset instead of the 35mm I bought. Mystery solved I guess--ordered some spacers today, we'll see how that goes.
2005 SL65 AMG
Awesome. Im not sure if its the same on your C as it is on my SL r230 but just pay attention to front vs rear spacers. On my r230 the fronts spacers are a different style than the rear
2000 ML55 sold? 2013 ML500,? 2017 C43 AMG,1929 Victory 6 roadster, 1927 Dodge 4 sedan, 1929 Dodge
We have had to buy 2 new rims due to cracks from pot holes.
14 multispoke rims.
Is your 450 4matic.
1 - 8 of 8 Posts
