ML55 AMG
Just wanted to take an opportunity to introduce myself. I have been a "shadow" member of this forum for a while, but have now began tweaking with the car in earnest, and require some opinions/advice from the established members.
Special thanks to Drew, UniquelySanFrancisco for their advice and posts in the past....
ML55 AMG
Discussion Starter #2
So,
Heres the situation
2001 ml55 AMG, Black on Charcoal Ash. I'm interested in updating the look of the truck by doing some minor upgrades...
1) Headlights - wanna do the 2002 look, but I am unsure if i need just the housings (and can re-use the existing HID low and Halogen Hi beam setup) even with some minor modifications, or do I need the entire Bi-xenon setup....
2) Interior LEDs, Mirror LED indicators, and Lit Entry Panels....
Some extensive wiring involved here, but I am not leery... Specifically with the turn signal leds (all over the car) will i need to install load balancers, (btw, what is a load balancer and where can i get one)...
I will be posting pictures of my truck soon, any advice is appreciated....
2020 MB GLE 450 4MATIC, 2015 BMW M4
RE: Lights
BillAMG - 5/1/2005 10:27 AM
So,
Heres the situation
You'll need new headlights, get the taillights while you're at it (there is a separate part number involved for the side markers in the taillights). The lights make a huge difference, IMO. Here are the part comparisons:
ML55 AMG
RE: Lights
Greg,
Thanks a million,
I need the entire assembly, eg both the lighting wiring, bulbs, ballast, etc.... AND the housing, correct? Or should I try to use the existing wiring in the new housing....
bjm
RE: Lights
BillAMG - 5/1/2005 7:22 PM
Greg,
Thanks a million,
bjm
The bi-xenons come complete with bulbs and ballasts. I'm not sure if a wiring harness adapeter is needed for yours, I think I needed them on my '98. They're not cheap, but are great lights. I also did a wiring trick so you can have the halogens on with the high beams--a lot of light.
