Unimog_404.113_1970
i was greasing my Mog yesterday, when i remembered the discussion about not using GL-5 in the Mog gearbox, because the additive´s could damage the "yellow parts" in the trans.
i wonder if there are any yellow components in the "joint" which connects the torque tube with the gearbox?
the question came up when i realized that i have a MoS2 grease, with EP additives, in my grease gun ..
if there are yellow parts in the "joint", can/will they be harmed, and in that case, how do i get rid of the MoS2 grease?
what grease do you other moggers use?
Unimog_404.113_1970
thanks for the post! now i´ll sleep better! [:D]
VMog - 5/10/2005 4:17 PM
As far as I know their is no yellow metals anywhere on the Mog but in the Tranny. You should be fine.
