2001 ML320 1998 Dodge 2500 Cummins Diesel 2004 Honda Civic EX (40 mpg)
Could someone give me detailed instructions for installing an Alpine remote antenna for the GPS unit (2001 ML320 MCS unit)? Thank You!
I have tried that page but what I'm asking is how do I get to the connector behind the unit?
2014 RX 350 F Sport, 2007 Scion tC, 2000 ML 430 Money Pit Finally Gone! Oh Happy Day!
You have to get a pair of removal keys to remove the MCS to gain access to the rear of the unit. Do a Search This Forum for 'MCS removal' for more information.
OK, so I got the unit out. When I looked at the antenna wire, it was pinched when installed and eventually rubbed the insulation off in a small spot. Would this be something that could short the GPS unit? Or do you think I should just try the remote antenna? Thanks for your help!
I should add that at my MCS, the antenna jack is pushing 4v acording to the cheapest piece of junk volt meter...which was the same as the roof antenna.
