Thank you will post it pretty soon.
MB PCMCIA to SD Card AdapterOk what is a cheaper option and have great sound quality,
Get a usb cd writer Amazon has it for $13
Find a memory card that allows use of sd cards (wanna get the right one i saw one didn't work for s class) from Amazon.
Or get a Bluetooth FM transmitter not the best option or maybe it was because the sound system was junk.
Dying to play my songs
Also might be correct im the only one in my small town with a benz. Have yet to see any.
I had this model and year. I ordered it new and it was delivered in early 2006, but was called a 2007 model year. Go figure. It was a great car, however they all had a bad timing gear. Since yours is old at this point in time, I assume it failed and has been fixed Years ago. Also the electronic module in the transmission failed around 60k miles. My previous s class a 1997 had the same failure. You symptoms seem different than mine, but it’s easy for a tech to diagnose. Once you get some of these items sorted out, you will really enjoy this car.Also how does Mercedes do the manufacturer date. It says 10/05 on the door, if i go off my math it makes it an 06 but the vin pulls up an 07 year. Had the insurance company check it when i was talking to them today.
Thank you i did look at the timing gear and chain looks new to my eyes. Note my phone doesnt take decent photos ($130 android phone)I had this model and year. I ordered it new and it was delivered in early 2006, but was called a 2007 model year. Go figure. It was a great car, however they all had a bad timing gear. Since yours is old at this point in time, I assume it failed and has been fixed Years ago. Also the electronic module in the transmission failed around 60k miles. My previous s class a 1997 had the same failure. You symptoms seem different than mine, but it’s easy for a tech to diagnose. Once you get some of these items sorted out, you will really enjoy this car.
Thank you its a great car minus fixing some issues. i was looking at a M class i think 07-09 model it had the diesel but i called amd it was pending sale, but definitely gonna have the dealership look everything over and what needs to be fixed my diy skills are decent but lack of decent tools stop me and its above my cut off for diy anyway to much stuff in the way.Congrats on the new car! These w221's are engineering marvels. Unfortunately that means you practically need an engineering degree to repair them. Preventative maintenance is the name of the game with these cars. At a minimum, you'll want to change every fluid in the car, as they're all likely way over-due at 15+ years and 120k miles. I believe the transmission fluid and filter are due every 40k miles, so you're now due for this car's 3rd transmission service. Assuming the previous owners actually did the first two services....
Engine oil and filter, engine air filters, I'd do those on day-1. Followed by engine coolant, brake fluid, transmission fluid and filter, rear differential fluid, power steering fluid, and the cabin filters. Spark plugs, serpentine belt and idler pulleys too. Most of this is easy DIY, except the transmission fluid which must be filled from below following a very specific procedure, and fluid level set with the engine running, and with the transmission fluid warmed to a specific temperature.
Make sure you use the correct fluids. Bad things will happen if you use incorrect fluids in these cars. Sites like fcpeuro or pelican will have the correct fluids for your car. Do not use generic autozone type stuff, you will regret it. As has been mentioned, you'll want to invest in a diagnostic computer that can talk to all the computers in the car and understand the Mercedes-specific codes. The cheapo $20 ones only talk to the engine and display generic not-too-helpful codes. Given the early production date, many of these service bulletins will likely apply.
Good luck with it, take care of it, and it will take care of you for many luxurious miles to come. I own a 2012 S350 bluetec (that's the diesel v6) and I wouldn't trade it for anything.
Yes but it's kind of a pain. It's in the fuel tank. There is a service interval but it's a long one. 150k miles? Can't remember. Some forums will say to replace every year. They're wrong.Also do these cars have a serviceable fuel filter.
