1 - 10 of 10 Posts
1986 300E
It sounds as though the AC compressor on my '86 300E is done. I have no plans to replace it, but would like to remove it or at least bypass the belt. Does anyone know or have the part number of a belt that would fit without the compressor pulley being in play. I thought somewhere in the world this car came without climate control and no compressor would be the norm.
91 500SL 37k,90 300SE sold, 91 300E sold , 92 300E137k ,02 Kia Sedona ,I know..... its a Mini van.
Drove Dieter yesterday,ext temp sensor registered 109F !!! no a/c crap! felt like passing out in there!
2008 E350 4M, 2016 Audi Allroad, 2019 Audi Q5
Not in the USA, but one exists...do a search and the dealership may be able to get one from Germany.
I'll eventually will fix it this winter maybe? good thing is blower works and center pods open and close! I think some one has had the dash off at one time,there are signs of it,sorry for the hijack!
1988 M-BENZ 300E | 1991 FORD PROBE GT TURBO | 2003 FORD EXPLORER 4x4
My recent A/C replacement is working great though this daily 100+ Texas heat. Although I still have not gotten around to fixing the RPM sensor problem, have to use a manual switch that is wired to the clutch.
If you don't want to spend a fortune on a new Mercedes compressor, do not settle for a re-manufactured, mine is a brand new four seasons (4S) and has been working great all summer. Don't forget to replace the expansion valve.
Mine was 4S part number 58336 "New Nippondenso 10PA17C Compressor w/ Clutch".
$251.99 special order at AutoZone or online.
So was yours a four seasons or a Nippodenso then?
Or is it a Nippodenso compressor, but rebuilt by Four Seasons?
95 E300, 91 300TE, 84 190D
103 poly belt lengths
So, to actually answer the question,
I don't have part numbers, only belt lengths:
2170mm belt for 103 engine, no air pump, no AC.
2257mm belt for 103, no air pump, with AC.
2330mm belt for 103, with air pump, no AC.
2415mm belt for 103 with air pump and AC.
1 - 10 of 10 Posts
