21 - 21 of 21 Posts
anything i want
Geeky1. the break fluid pushed back up into the line,(like some els stated) that is the problem. machanics do that because it's faster/easier than bleeding from the calipers. if you get someone else to do your brake's? make sure to ask them to bleed them from the master cylinder....
if your calipers were sticking it would most likly be a different scenario, like a pulling to one side or the other. as far as the aftermarket dust covers,i've never herd of a problem with heat build up. good luck[8D]
21 - 21 of 21 Posts
