My 560 is going through brake rotors much faster than I think it should. I've had it for 2 years, put about 25000 miles on it, and been through like 5 sets of front rotors.
Yes, 1 set of rotors every 5000 miles. I don't drive the car THAT hard, I try to avoid panic stops, but the rotors always end up getting warped after a few thousand miles.
How do I know that they're warped? If I step on the brakes at 60-70mph or so, the whole steering wheel vibrates. It starts off as a slight vibration, but the older the rotors get the worse it gets. Replace the rotors and the problem is solved.
This isn't normal. It can't be. Any idea what's going on? There's gotta be something causing this- something else that's wrong with the suspension or something.
