1 - 16 of 16 Posts
190E 2.3 & SLK230K
well...
my last final is tomorrow and im officially on spring break...hehe
so i'm gonna have time and will be able to service my car...
it's got 36,642 miles on it right now and i'm going to get the:
-oil changed with mobile 1 synthetic
-transmission flushed
-differential flushed
-radiator flushed
-front brakes
-roof joints lubed
any other fluids i should get replenished?
how often should the above mentioned fluids be changed? mileage? time?
BenzWorld R170 SLK Host
2002 SLK32 AMG
Just my opinion but,
Engine oil with Mobil 1 every 5K
Transmission Fluid every 30K
Differential Fluid every 30K
Radiator flush every 3 years regardless of mileage
Front brakes when they wear out, could be anywhere between 20K and 50K depending on how/where you drive.
Roof joints lubed every year regardless of mileage
Others:
Brake Fluid Flush every 3 years regardless of mileage
Power steering fluid flush every 3 years regardless of mileage
Not really sure about the supercharger oil, but I'm thinking 30K would be a good time to drain and refill.
Battery electrolyte level, check every 3 months and add as necessary.
2002 SLK 32 AMG
I like Brian's suggestions with a couple of changes:
MB Service Manual suggests changing the brake fluid every 2 years.
I think I'll lump the transmission fluid, differential, power steering fluid, and supercharger oil all into a 50,000 mile fluids change.
I also live on the edge I guess, I'm doing my oil changes according to the FSS schedule, about once a year or about 10,000 miles. From what I've read (here and elsewhere) the Mobil 1 should easily last 10,000 miles. I know most people are changing at 5000 miles to be conservative.
99 slk 230 sport
I would like to do as much maintenance myself as possible. Anyone have a recommendation for lubing roof joints? How about the rubber, is their anything that can help them? I was thinking of a thin coat of petroleum jelly.
01 SLK 320 MT6
okieslk - 3/18/2005 11:21 AM
I suggest getting special stuff from Mercedes, some lubricators are bad for rubber.
SLK32, ML430
The brakes are easy. It should take you less than an hour to change the front pads yourself.
I thought the SC was sealed and there was no way to change the oil.
2001 SLK 230
Brian_R170 - 3/17/2005 12:41 AM
Others:
I like these suggestions. I changed everything that you listed Okie at 42,000 miles, and it was way too long in my opinion. The tranny fluid was dark and the differential oil nasty. I spent about $300 in just the supplies to do what you wrote, including the purchase of a tranny dipstick, etc. I think you'll be out about $1200+ at the dealer for all of that.
2001 SLK 230
okieslk - 3/18/2005 10:21 AM
Search this forum and you'll find the Mercedes part number for the lubrican that you put on the rubber seals.
Does anyone know what kind of oil we're supposed to use on the roof hinges? Anything special, or just 3-in-1?
2002 SLK 32 AMG
430 - 3/18/2005 10:29 AM
Can anyone confirm that this is the case? I don't want to look (more [:eek:)]) like an idiot when I ask them to change it if it can't be done.
I also have about the same mileage (37K), and I am off for spring break (I'm a teacher) and have an appointment for Monday morning -- service B. I guess I should be getting some of the same things done as well?
Transmission flush and Fluid
Differential Fluid
Radiator flush
Roof joints lubed
Brake Fluid Flush
I better get my check book out.
1 - 16 of 16 Posts
