my glow plug indicator light stopped working yesterday. the car had a very difficult time starting but finally did. tried the car again this morning but it would not start at all. incidently, the indicator light started working again. i turned the key back and forth several times to allow it to turn on/off hoping it they would heat up. it never worked. i was going to plug it in but i couldn't find an ext. cord to reach so i just took my other car to work. i played with the glow plug relay connector and they all looked clean. i took off the metal strip fuse thing and it looked like it was in fine shape.<p>: what to do? i'm not sure really. i ordered 5 new glow plugs, a new relay, new fuse from performance products to try and fix the problem. i am very much a novice at mechanical work. is this something i'm going to be able to handle? i have the illustrated fix-it book to help guide me. anything in particular i should try before i get started? what should i try to replace first? all help is greatly appreciated.
