1 - 8 of 8 Posts
Im a diesel newbie I think I’m getting a fuel leak not from the injectors I think it’s from the 5 and 6 glow plugs. Number 4 is dry. I don’t see where else it could come from back there.Are those common to leak? I’ll be checking it out better this weekend. Just wondering if anyone else has had this problem.
never heard before... is glow plug light working as it should?
Only thing that could cause 'black death' under plugs is that someone changed plugs but didn't tight them properly. Are you 100% sure its fuel and fuel only, and its not dripping from injector or pipe connectors? Fuel not dripping from above (injector footwell)?
I sprayed degreaser on that area and pressure washed it all off. Hopefully I can spot a leak.
I haven’t figured out the leak yet. I washed off all of what I think is fuel. Didn’t leak nothing only after I drove for a while . Couldn’t tell with all that crap in the way. That plastic harness thing next to the turbo pipe is there only like wires in there?
2603665
2603666
Stuff some paper towels in the area and recheck them frequently.
It does look more like fuel on the picture, but fuel leak will always wash some dirt on the engine, so hard to tell.
Could be also coolant leak. Do you check the level?
Coolant levels good . I had wedged a piece of cardboard where I suspected. Between that turbo outlet pipe .A little more patience and I’ll find it. Hopefully it’s not hard to fix.
2603734
1 - 8 of 8 Posts
About this Discussion
3 Participants
Blazed
Mercedes-Benz Forum
Full Forum Listing
