Greetings gentlemen,
I have been having some cold start issues since the weather got a little colder here in Texas. Whitish smoke emits from the exhaust for about 45 sec after start and I could tell that one of the pistons was not firing properly for the same duration. Once it fires though, all is well and she drives like a champ. Got out the multimeter yesterday and checked the resistance of all 6 plugs. Plugs 1-5 all had resistances of 0.6-0.9kΩ. Number 6 was a different story, coming in at 75kΩ. What's depressing is that I replaced the plugs 2 years ago (with Bosch) and have only put about 20,000 miles on the car since then. At any rate, I have decided to do the glow plugs myself and wanted to make sure I didn't miss anything. My checklist is below.
After inspecting the car today, it looks like I will need to remove the throttle linkage then the part of the manifold that crosses over the engine. From there I can remove all the screws to the manifold and get access to the plugs. Please say a prayer that none of them break.
Clayton
Anti seize for the plugs.
Gasket for intake manifold ($129 on AutohausAZ, yikes!)
6 Bosch glow plugs ($18/plug on AutohausAZ)
T40 torx and some good pliers.
Clayton
