2000 ML430
Does anyone have a DIY on taking the glovebox cover off. My glovebox is having problems closing. Looks like it is off the hinge. Thanks for all the help in advance.
I don't know about taking just the cover off, but going from memory when I took the box out on my MY02 320 to do my VES install, there are a couple of screws on the bottom part and I believe on the sides to take the entire glove box out. The two screws on the bottom are plastic press on type so you may have to replace them if you take them out. If you take the box out, you will find the track for the cover, and maybe adjust from there. If it's different from the 430, then man, I can't help[8D]
2000 ML430
Thanks darkman. I'll try it and see if it resolves the glove box issue. Thanks again.
