first glove compartment
i got the ipod thing hooked up so i tried hiding the lines
somewhere along that line i didnt do anything wrong i close the compartment
and open it...
the compartment just drops
as before it droped quietly and slowly
now it just drops by the gravity
how can i fix this or how much would it be?
also moonroof
i had this problem ever since i bought the car
it would shut n then open half way
i took it to benz twice when i had warranty
its doin it again but i dont have warranty
since its a on going problem does benz fix this for free?"
1962 W111 220SE Coupe
Glovebox: It seems like you may have gotten the slide arm off track, or possibly broke it. If someone here has an exploded diagram or photo of a disassembled glovebox it may help you see how it fits back on.
Sunroof: How did the dealer say they fixed it those two earlier times? Was it a relay, or maybe just a failure to sync the sunroof? You may be able to try the re-sync procedure which is to hold the sunroof button down while it closes the and then without letting off, keeping it held for a few seconds after the roof has closed entirely. Side windows click when you re-sync their one-touch feature, but I am not sure with the sunroof. This should reset a sunroof that lost it's sync perhaps from disconnecting a battery. Do you recall if the other times it stopped working properly had you or anyone else disconnected the battery for service to the car in some way?
