How do you take out the glove box? The box inside the glove door? I can't close my glove door cause that hinge some fell off. When I put it back on, the screw when threw the hole and went inside the glove box...
G
Guest
On my 85 300D there are around 4 gray plastic pins
on the top inside front of the glove box you need to
pry out. then pull slide out the inside of the box
might have to pry the top part down past the lock mechanisim.
