We purchased a new GLC350e last summer and have had chronic cooling issues ever since. Wondering if anyone else has seen similar problems.
When running on the battery we often get a cooling system fault light on the dash display. We’ve had the car in for service 7(!) times now and they’ve not been able to identify the source of the problem, much less repair it. I don’t see references to this sort of issue on this forum, so perhaps not a common occurrence?
Anyone heard of this sort of problem before?
· Super Moderator
1986/1990 W126
That's a complex machine. I bet it drives great though.
Coolant indicator on this, is it for the motor, or does it also include the EV battery?
There’s a coolant temperature indicator for the gas engine but from what I can tell the fault light is for any of the three cooling systems (2 on the engine and one for the battery.)
When it runs properly the vehicle is an absolute road machine. One just has to be cautious about going somewhere on battery power, which defeats the purpose of have a plug-in car.
So far the dealer has replaced one of the motor/pump assemblies, a temperature sensor, the controller for the coolant at the battery, the engine wiring harness, upgraded the software for the engine computer, and repaired a connection on the wiring harness. The problem is still there.
As much as the wife loves the car, we’re at the point of turning it back in as a lemon. If the dealer, the corporate office, and the factory all working together can’t properly diagnose and repair a problem than I don’t want to be on the hook for figuring out what it is when the warranty runs out.
its not a good car ...my 350e bought new in 2018 (out of warrantee) in been in the garage 3 time in the last 6 months ...$$$$ thousands later still does not work....mercedes should not make electric cars...cooling is just one of many problems
