Hi,
Came out of the store and no start. Kept cranking with no sign of firing up. Towed home. Replaced fuel pump relay, checked fuses, no luck. Removed air filter housing, poured some gas into air intake and it fired up and running for few seconds smoothly. Repeated several times and fired up every time running normally then died. Concluded not getting fuel. Ordered and replaced both fuel pump and fuel filter breaking my back with no results. No codes. No history of not firing up. Have had the car for about 5 years. 160K miles. Both batteries new. I thought because it fires up when I pour gas in the intake it shouldn't be any of the sensors or the key not communicating. What else should I look into? I don't have any advance tools or software just a basic MB code reader. If aware of any previous discussions here, please guide me to. Please help. Thank you.
