03 G500
What is considered normal oil consumption on the GL450? Any service bulletins regarding this matter?
560 SEC Supercharged(sold), E55 AMG, Renntech CL600 Bi-turbo, Porsche 928
I have over 80,000 miles on my GL450 and it does not require any oil between oil changes. My change intervals are greater than 10,000 miles.
'07 GL320CDI
More than a quart between changes should be too much.
If yours is brand new, you should wait a while.
03 G500
I have 40,000 miles and the engine's seen 3 quarts since the last change about 2,000 miles ago...
2006 E320 CDI, 2009 ML320 Bluetec, 2009 GL320 Bluetec
What kind of oil are you using?
Have you owned it since new?
High oil consumption would indicate en engine overheat or coked compression rings from the use of conventional oil.
Also if you are using a 5w30 or worse a 0w30 these are not an approved viscosity for your engine in North America ( temperature issues).
