Hello. My wife's 2012 GL450's airmatic is stuck on the up position. When you press down to lower the light just flashes but the car doesn't lower back to normal height. I've check the 2 orange 20A fuses and also the green relay and all 3 looks fine. I also had our mechanic check all the wiring on the air compressor to see if any were loose or broken but he didn't find any wires that were broken. I forgot to ask him to check the valve to see if it's stuck or clog while he had the wheel off. Do you know where the valve is on the compressor? Attached is a pic that I circle in red in which I think that is the valve. Can anyone confirm if that is the valve I need to check to see if it's stuck or clogged?
Also is there anything else I can check besides the valve? Thanks!
