My GL 320 CDI went into a limp mode with a check engine light on. I checked the code and it came back as P1402 - possible EGR valve issue.
A new valve is about $350 while a MB dealer replacement goes to about $750.
I took the valve apart and I cleaned it. Everything works perfect.
The valve is located all the way in the back near the fire wall on the driver side. To access it you have to remove the top side of the protective wall. remove both electrical connector before attempting to remove the two screws. After the screws are removed easily pry the valve open with a mechanical flat heat screw driver.
The valve has two small cooling hoses attached at the bottom that distribute engine coolant to the EGR valve body.
Once the valve is out take all the plastic covers out, measure the coil and clean the carbon built up while making sure the spring loaded mechanism works.
Pictures attached.
Pictures attached.
