Mercedes-Benz 115 cdi Vito
Hi All
Pls help me my Vito 115cdi left indicators stay on :confused:not even flikering
Globes got so hot i had to remove all 3 of them, I check the
indicator on stearing wheel but all seems fine, check all fuse
by removing 1 by 1 to see if the indicator light will go of but
to my suprise nothing...:surrender:
So coul any one maby give me some advise PLS!!:bowdown:
Still don't know my Vito well enough to offer direct advice, but basically, you need to find and replace the turn signal flasher, which looks like the part on the right (btw, this photo is not from a Vito!!! LOL ours will be hidden under layers of plastic...)
E-how says: When a left or right turn is indicated, the electricity flows through a device called the thermal flasher to the front and rear turn indicator bulbs, and to the dashboard turn signal indicator lights. The thermal flasher is the heart of the turn signal. It turns the light on and off using a process that has not changed in decades.
Read more: How Does a Car's Signal Lights Work? | eHow.com How Does a Car's Signal Lights Work? | eHow.com
Once you find it, changing it will (should) be simple.
