1996 SL500, 2003 CL55K, 2005 E55K Estate
are the ones available form ebay any good?
are they universal for any merc?
any advice on the length of the dipstick i should be looking at?
cheers
'01-E320 & 02-ST2
It's not a "dipstick" in the conventional sense. It's a tool that is used to check/set the fluid level, and then removed.
As such it is common for all 722.6xx transmissions. The ones on ebay seem to be fine, like the el paso tool folks, for example.
Note that you also need a reliable way to measure fluid temperature, as that is a critical factor related to fluid level.
For more information (probably more than you want) you might have a read through the 722.6xx FAQ thread located in the W210 forum help/diy stickies.
Good luck.
