1 - 8 of 8 Posts
ML 320 cdi 164 2005
hi i have an ML 164 320 CDI, when first started and driven gearbox is fine, if you turn the car off say to gas up, when you then drive off it wont go into gear 6 or 7 for about 60 seconds, no limp mode or dash lights has always done it in 7th gear but just started to do it in 6th, the truck has done 156000 miles, any ideas anyone
2007 ML CDI, 1967 250SL(early), 1984 280 SL, 2004 E320 wagon, 2015 ML 250, 1999 E300TD
will it go into 7th if you use the paddle shifter?
is there any slippage during the gear changes?
on my 07 ml cdi there is a hill desend button that keep trans out of 7th gear. It just above ash tray. I mistakenly push button and activated the hill desend and it would not go to 7th. I thought trans was bad, but it was the button.
That's all I can think of?
ML 320 cdi 164 2005
thanks for that, no paddle shifts won't change the gears even if you are going at the right speed for it to change, no slipping of the gears very smooth and when it does change gear eventually there is no slipping, and the hill decend button had not been pressed as i have done that before myself!
His 2013 RAM Cummins Turbo Diesel Laramie; Hers 2007 ML320 CDI P3; Kids 2010 "4Matic" Impreza
156000 miles.. That's neat.:thumbsup: I'm at 112000 so just a "hair" behind you.
As for the 6 and 7 shift issue, the transmission fluid temperature has to be warm to allow these shifts, so if it is in fact warm, maybe the fluid temperature sensor is bad and not letting the transmission computer recognize that it is warm enough to shift?. Just a guess here mind you. Probably best to let the dealer or an indy put it on the Startek computer and see if something shows up.
2019 X350d, 2017 GLE500e, 2012 ML350BT (sold), 2013 A200 Exclusive(sold), 2009 ML350CDI(sold)
It happened to me once and only once. My solution was to boot it give some revs for 200 metres then settle back and it was fine.
It was a cool night, so may be consistent with dgiturbo's suggestion.
ML 320 cdi 164 2005
it does it when its warm or at normal operating temp, when its cold its fine, had enough of the local merc dealer nice chaps but cant afford the bills! so will keep driving it till it breaks i guess
83 300CD, 07 ML320 CDI, 04 WRX, 86 300D (totalled by my neighbor), 85 300D (sold)
A few questions:
1) How often does this happen to you ?
2) Did this happen right after your vehicle was not in use for a long time ?
3) What year is your CDI ?
ML 320 cdi 164 2005
A few questions:
it happens every time the only time it does'nt happen is when the car is first used at the begining of the day, vehicle has been used every day for 2 years it used to do it randomly in 7th gear every now and again, its a 2005 164 thank you
1 - 8 of 8 Posts
