Hello There!
We really hope someone can help us!
We recently got a new SKL 200 Kompressor 2006, yesterday we wanted to replace the old Radio with a new DVD GPS, we had to open the gear box, clima, and remove the old radio.
All was fine, the new radio works fine, the only issue is that after we close everything, we noticed that we were able to move the gear only D to N and N to D.
As the car is not on a superfice but it is on a hill, we were able to drive in front and got back thanks to the gravity and pendance of the street, in this way even if we were not able to change to R, we were able to park the car again.
The only thing is that after we park the car again, we turn it OFF, now the car is parked and the gear stuck on D...... No way to move it.
We tried to remove the radio and put the old one, we also tried to remove the battery from the car and connect it again.
What do you suggest??????
Moderator
190E, SLK350
When you put the radio in, did you mess with the center console? See if you didn't drop something in there.
Hi man, thanks for your message.
We basically disconnected all cable and then again.... No idea what happen :-///
Now we do not know how to move the car
Hi
Are you sure you are speaking about stuck in D and not P?
Can you send us some links?
Thanks!
