How easy is it to remove a gear shift surround to get to the bulb?
Can you show pics or step by step, mechanically inept here.
Thanks,[:)]
To take off the wood just take off the carpet on the center console and there is a screw there take it off put the shifter on N and lift it up and there should be harness infront and on the bottom of the shifter going to it. Pull it out and there is your bulb. Be careful because the switches are attached to the wood so don't lift too hard.
