This is for syn fuchs75W85 not the conventional 85W90Wow, that is a pricey dealer. Mine listed it of $27.13 and sold it to me for $23, but the
good news is you got some great fluid to keep the diff happy for years.
I am running Mobil1 75W90 full synthetic.I believe so, they will both work and are blessed by MB. I just stuck with what the owners manual said.
No its for the MB spec'd 235.7 85w90. In the US 85w90 is not sold or available on the market since the majority of car makers do not require the higher viscosity fluids.This is for syn fuchs75W85 not the conventional 85W90
85W90 is conventional and I specifically ask for 75W85 and the answer was 55$, plus needs to be order. I do not know and did not ask how much 85W90 is. Dealer is selling Valvoline 75W90 for supplement 15$ a bottle. Star service DVD for USA states that Fuchs synthetic fluid can be used on cars produced even before 2001 (Fuchs become available in 01 and has viscosity index of 144) and you are saying that conventional oil will perform better than synthetic? Why not using conventional engine oil instead of synthetic, will be cheaper? You cannot buy Mobilube LS 85W-90 (viscosity 100) Limited-Slip Gear Lubricant anymore because is been replaced by Mobil Delvac Synthetic Gear Oil 75W90 (viscosity of 140) widely available for commercial trucks that meets MB 235.8 specs, also Lufteknic Porsche web page(http://www.lufteknic.com/Merchant2/...ode=Mobil75-90delvac&Category_Code=lubricants) and Mobil Delvac web page(http://www.mobil.com/USA-English/Lu..._Delvac_Synthetic_Gear_Oil_75W-90_80W-140.asp). The viscosity index for Mobil1 synthetic gear oil is 150. Therefore, 144 and 150 are not that far and you should agree that if the viscosity is the most important for gear oil they should provide same levels of protection. I think that all oil properties are important, for instance, 80W140 has viscosity index of 139, but cSt @100ºC is doubled and at 40ºC is 2.5 times bigger compare to 75W90.No its for the MB spec'd 235.7 85w90. In the US 85w90 is not sold or available on the market since the majority of car makers do not require the higher viscosity fluids.
Ok, people everyone who is been following this thread: Please look all the pictures I am attaching and tell me what is wrong whit them? I want answers based on healthy thinking over those pictures posted; not just chewing same words repeatedly, because you are afraid that thinking can gets you a headache.85w90 is a synthetic...it is produced by Mobil for Mercedes List is around $30 per liter, if they cut a deal it can be had for around $26.00. This is a high end synthetic not a conventional lube which is why MB is using it on more and more applications becuase of its better protection to the differentials.
In the US we pay about 1/2 the price for lubricating fluids.
The critical operating temperature is 40C for a differential.
75w90 is does not provide sufficient protection in most MB applications.
NEVER use a 75w90 in a US Spec differential.
Just an example that your differential stil will be protected if you use 75W90 synthetic or conventional, or 75W85 instead of 85W90. I think that you are trying to trash yours if you been putting 85W90 instead of 75W85. READ, READ AND READ EVERYTHIN, do not hold on yours.So what does a 1997 Supra have to do with a Mercedes Benz topic and 75w90?
The fact remains that only the viscosity range of 85w90 is approved unless otherwise stated for your model.
So you are saying that Star Service Manual which covers all USA W211 models from 2003-2008 it is wrong about 75W85 oil in our differentials, that is been fill up in the factory. In addition, the oil manual you are using, mentioning same oil for your ML and GL with or without differential lock, or for G-WAGEN with differential locks is wrong.It depends on the model, some require a thicker fluid ie 75w140 so yes "Unless otherwise stated" because the higher performance models need a thicker fluid.
The issue again is the 85w vs the 75w and that the 75w has 1/3 to 1/2 the viscosity at 40C when comparing to the 85w under the MB235.7 fluids.
The fact is the Manual says that you are wrong, so if you choose to use the incorrect fluid thats your choice.
w211 uses 14mm.OK, here it is. Just got my new original manual for my euro W126 380SE. It says 1.3L Hypoid gear oil SEA (sic?) 90, 85W90. So, I figure I should change it, since who knows when it was changed if ever on this thing. My question is: what is the allen wrench size(s) for the drain and fill plugs so I can procure them?
