Mercedes-Benz 560SEL mod 91,MB 560SEL mod 90
Hello Guys,
Because of some annoying sounds, engine is vibrating and as if it seated on a piece of metal, I checked the engine and gear mounts and found bad. I changed those mounts but I noticed the gear is almost touching underneath, there is a gap about 8.0 to 10mm only as you can see below. Is this normal or is there something wrong. What I expect is a gap of about 1.5 to 2 cm or am I wrong? Any idea would be greatly appreciated. Thanks in advance.
Problem is solved
Hello,
After I installed the new engine mounts, the engine is still sitting down and there is not any progress being noticed so, I removed the engine mounts" the new ones " and inspected and found they look very soft and very easily be pressed and not able to handle the engine weight. I think they are not really genuine mounts, I took them to the seller and get money back. I bought another mounts from different new part store and installed. Engine is now lifted up and the gap which was under the gear became bigger, the engine was vibrating because of the bad shock obsorbers. Now problem is solved, engine running smoothly no more vibration. Thanks to all of you.
