Install connections in console - 1
I wanted all of the input connections and the mode selector switch in the console. These may be placed in the glove compartment far more easily – all, or in any combination. However, I elected to do it the hard way, for future convenience. The first photo shows my upper console compartments (phone and storage), open. The false floor is held in place by three Star screws (#10 driver), two of which are under rubber covers.
I removed the false floor to reveal the MHI phone wiring and Tele-Aid button connector, and disconnected Tele-Aid buttons by prying the side with the small retention clip. The MHI wiring slips out of a slot in the bottom of the false floor (on the back), and need not be disconnected. See second photo, below.
I drilled a hole in the back wall of the false floor using a ½ inch drill bit, and then had to enlarge it to allow the USB connector and 9-pin iPod connectors to pass. I ground the two side flanges off of the AUX/mode selector, and used the two small screws that hold the back panel onto the switch to affix it to the back wall of the false floor as well, as shown in the center photo below. I also cut a notch below the mode selector to allow its wiring to pass. Inside the tiny hole in the Aux/mode selector in the center photo is the reset button.
I also drilled a ½ inch hole in the back wall of the lower part of the console, and enlarged it to allow the connectors to pass. The hole is just below the curve of the black wires. This hole lines up with the similar hole in the false floor. Careful when drilling, so as not to hit your console exterior! 4th photo below.
Below the holes, by the hinge, is a small rectangular tab, which snaps out (5th photo). It is large enough to allow each connector to pass, and be fed to the console floor. I fed the connectors through the two holes drilled, and through the hole for the removed tab. I could not thread the wires through the hinge itself because the space is already occupied by other wiring.
In the 5th photo, the hole exposed by removing the tab is shown with a tan wire passing through it. I started to use this wire as a “fish” but found the connectors would drop straight down to the console floor easily enough (with a little coaxing). I had also removed the console light fixture as a potential aid to fishing the connectors, but this turned out to be unnecessary.
