hello there, i recently purchased a 190e 2.3 1993. among other issues my car has developed a fuel odar inside the car once i get it started. if anyone out there has an idea please forward me a response. thanks for all your help. kevin[:(]
check under car behind left rear wheel. should be a plastic cover with 2 10mm bolts. take off the cover and check your fuel lines running from the pump and filter. i just had this same problem and turned out it was a leeking fuel fitting on the fuel pump. this was on a 190e 2.6 so i dont know if yours will be the same.
