1 - 19 of 19 Posts
1987 560SL midnight blue on grey; 2003 20th AE Volkswagen GTI Imola Yellow;
Hi all,
after draining the gas tank and dismantling the whole fuel delivery cluster, i found out one of my fuel pumps is stuck and had black sludge in it (intake part). it hums when i hooked it up with a battery charger but wont turn. the check valve is a bit rusted. the secondary pump is clean and works pefectly.
my question is, is the pump salvageable? if I clean it good enough, lil tapping, do I have the chance of getting it unstuck? or should I fork over the $$ and get a new one.
( i dont have an idea what the nature of the sludge is, car sat for a while with barely any gas.)
pics:
thanks!
· Outstanding Contributor , Bob's Your Uncle!
83 280 SL- 5 speed-The PIG
That's pretty gross.
You could reverse the polarity on the pump and run it backwards...maybe running fresh gas as a solvent. What have you got to lose?
I, myself, as an experiment, would try to save it.
1959 220S cabriolet, 1983 240D original owner, 1999 E300 turbo diesel, 1988 560SL, 2003 SLK320
Hook it up backwards and run diesel through it not gasoline. I've got the text of the procedure if you want to try it. Contact me offlist.
Len
[email protected]
· Always Remembered RIP
1973 450 SLC AMG, 1995 Chevy Tahoe
Eeeeeewwwww go new.
1981 380SL - Lorinser bodykit w/16x7 LOs - AKA "Frau Blau"(Lady Blue)
I am liking Knobby's idea. Pull it apart, it won't hurt anything to do it and might learn that it is repairable/rebuildable. If not, there is always new.
Bandit
Len
[email protected]
Why diesel? I've heard that but never understood.
Gas is a much better solvent for that tar.
1978 280slc
I'd fill it with solvent and use a vibratory mixure to dislodge the gunk. I'd also to it outside just in case.
Yes, a safety issue. If you use gasoline, you will probably only do it once. :)
Len
COOL!
1 - 19 of 19 Posts
