2000 G500 NMLE
I just finished this job. It's a real "trip", since the lower oil pan must be removed; and there is no gasket used. Only Loctite 5900 Sealant.
If anyone needs to do this job, let me know; and I'll give you some tips to make it easier. It was a genuine learning experience.[:0]
2000 G500 NMLE
Discussion Starter #2
FWIW, the presenting problem requiring this job was not a lack of function of the oil level sensor; but a slow oil leak down the right side of the oil pan. This used to be only an occasional spot on the garage floor, but turned into a regular drip after driving.
There's an O-ring that seals the sensor into the upper oil pan, and dirt and grit can work their way down into and around the O-ring causing it to leak.
00 g500
shoulda read the second post earlier. Who cares if the sensor does't work, but it's always good to have pit tips to fix a drip. Erik
