1 - 9 of 9 Posts
1983 300TD, 1977 300D
We're just finishing up this military-spec 1991 300GD conversion. Swapped out the OM617 NA diesel engine for a high-performance 617A turbo-diesel, and the automatic trans for a 5-speed manual transmission.
Though y'all would want to see some pictures, because who wouldn't want this as a daily driver?
More on our services
I admire the completion. (estimates is that 99,98% of such projects never makes it to finish), but dust-sucking air filter is in wrong place.
It belongs in garbage can.
the stock turbo actually makes quite a bit of boost if it's adjusted correctly.
also, the high-performance injection pump has a custom ALDA
also, after a fresh rebuild it's best to break it in with the stock turbocharger and then upgrade it if desired.
Boost does not mean power. The T3 is very inefficient and restrictive, especially on the exhaust side.
That doesn't make any difference.
No, thats not true.
Well we will have to agree to disagree. You are not the all-knowing truth in the universe and you can blow up as many engines on your own time and money as you'd like.
Scientific fact? Trolling?
Sure buddy...
Listen, just because you don't know how engines work doesn't mean you should be giving such a shitty attitude to somebody trying to help you have a better running engine.
1 - 9 of 9 Posts
