ML430 - sold
Just got back from a 1,200 mile road trip in the ML and I'm pleased to report it ran like a top and returned over 20mpg.
However, part way thru' the trip I noticed the rear passenger side brake light had failed - no problem, I'll fix it at the next gas station. WRONG !
Discovered that the plastic nuts are torque down way too hard and cannot be shifted, so decided to complete the road trip with a brake light out - no big deal.
This is where it gets interesting.
On arriving home I get out my socket set and remove the retaining nuts. Then following the intstructions in the handbook I pull at the light assembly - very hard, it won't budge.
Finally with a lot of force it comes free, but I notice the cheesy plastic retaining assy has broken in. Fixed it with some epxoy and a bit of vaseline on the pin to make it easier for next time.
Now, this is the bit which got to me - so the brake lamp had failed, no problem off down to the NAPA store with the failed brake bulb and other working bulbs, thinking I'd get a full set of spares - WRONG again.
Seems MB in their wisdom use a different angle offset for the locating pins on the indicator and other lamps - only the brake light is standard.
This means you're unlikely to get replacements without going to the dealer.
Another MB design tweak to maximize profit - why move the pins from 180 degrees to 120 degress ? Surely 180 is optimum ?
Moral - make sure the retaining nuts are not too tight, the locating lugs are greased and don't count on being able to buy replacement bulbs from auto spare stores.
The rear light bulbs from Mercedes (with 120° pin offset) are 4 watt and not 5 watt like the usual bulb with 180° pin offset.
I noticed that with some wiggling the 5 watt bulbs with 180° offset fit and produce a better amount of light.
ML 320
It is true that the lightbulbs that MB uses are far less common, but I found them pretty easy after a few telephone calls.
The same bulbs are also used by several other european vehicles.
